In the help file for updating custom metadata it says
When you create a custom metadata field, you give it a name. DEVONthink uses this name to create an identifier for use in automated processes. This identifier is created automatically and cannot be changed.
I have a custom metadata field MyComment which takes text. I would like to update via a script.
I am having problems doing it. Is this the proper way of coding it?
set myNewComment to "Hello World"
add custom meta data myNewComment for "MyComment" to theRecord
theRecord would be the currently selected document.
Thanks
