Hello team,
i’ve been trying to fetch data from a website which is updated daily several times to keep informed about changes which match to my search criteria.
In order to automate this i created a search-set with my login credentials.
For some reason it does not deliver any result. I assume the login does not work.
Is there any workaround to use the login? For example use the built-in webbrowser inside DevonAgent to manually login once a day and then perform the searchset inside it, so that no additional login is required?
The website of interest is some group inside xing.com.
Any help is appreciated.
Regards
René
