Hello Andrew
A new “instance” is something different – it’s not to be pedantic
Just to check that I understand you correctly. You are using New > Bookmark with an x-devonthink-item
link to a group in the URL field?
I actually never tried this. General bookmark behaviour: If I select a bookmark to a website, it opens in the view pane. If I double click it, it opens in a new (document) window. I just tried with a DEVONthink group, and the behaviour is consistent. When I select it, I get a gallery-style “Icon View” of the contents of the group in the view pane. I actually didn’t know this, pretty cool! (Even if I can’t immediately think of where I might use this). When I double click to open, it opens in a new window like any other bookmark.
Can you describe your use case in a bit more depth? A couple of options come to mind.
You could use replicants. But if you intend to have the same group referenced many places, it might get confusing. I would prefer to replicate the same document in different groups, where I want to “link” stuff together. Or you can use tags as a way to “link” similar items.
The simplest way to approximate what you describe is probably to use a text document (markdown, RTF). If you click the item link from here, it will take you to the linked group in your current window.
In a text document, it is also easier to add links compared to creating bookmarks. If you hold ⌥⌘ while dragging a group or item into the text, it will automatically create a formatted item link for you. You can also use the Insert Link popover: ^⌘E or Edit > Insert > Item Link. (See Windows > Popovers in the manual, they’re pretty handy.) Or wikilinks, but they are less stable if you rename things a lot.
PS: you might want to check the different parameters for x-devonthink-item
links in the manual under Automation > Items Links. They mainly apply to documents, though. For example, if you add the reveal=1
parameter in a link to a document, it will show in the current (database) window instead of a document window.
