Hi, I’m a newbie to devonthink and markdown. I’m learning to utilize devonthink and markdown for my studies while working with PDFs.
First of all, my first big question is this:
I’m not sure if it’s okay to use only the markdown editor included with devonthink for studying purposes, or if I should use other markdown editors as well. -
the second question is about a problem I encountered while thinking about the above.
(1) For those of you who use devonthink well, when inserting images into markdown, do you insert images in the form of ‘x-devonthink-item://…’ with the image reference as an item link? with the image reference as an Item link.
(2) Or do you set it to automatic and insert the image as a file path (ex:[Image 2024-01-14 212215] (Assets/Image%202024-01-14%20210000.png))?
When I used the ‘x-devonthink-item://…’ format, it seems to have disadvantages of incompatibility, such as not being able to check the image in other markdown editors. However, it seems to have advantages, such as being able to check the link and incoming link of the image and markdown file in devonthink.
The file path format seems to have the advantage of being compatible so that images can be viewed in other markdown editors. However, it seems to have the disadvantage that it is difficult to check link and incoming link in devonthink.
If I can get away with just using the devonthink md editor, I’d like to insert images in the format ‘x-devonthink-item://…’. If it’s better to use it with another markdown editor, I’d like to insert the image in the form of a file path. What would be more effective?
Thank you for your feedback and please excuse my poor English ![]()
