Hello,
after reading this blog post:
[DEVONtechnologies | How to Use Emojis safely] DEVONtechnologies | How to Use Emojis safely
where you pointed out the use of emojis in meta data fields, I was just trying to fill the field name with emojis. This leads to much better visibility, especially if you have a lot of custom metadata fields. It works so far, but the name (with the emoji) is not synchronized. Is this intentional or a mistake?
Thanks and best regards
Chris
