I’m trying to use the “Download URLs as PDF documents (Paginated)” script in a smart rule (copied to smartrules folder). It runs but doesn’t work.
I’ve added the on performSmartRule lines (2). I’m not an expert so prob something else is needed. Maybe using selection is the issues instead of theRecord (in theRecords).
When I run as is below, it just hangs on the status “Downloading…” xxx. I have to restart DT as it’s stuck in that loop I think. The smartrule is triggered on clipping a webloc kind. I’m clipping a URL that links to a PDF. When the script is run from the menubar on the same webloc selection it works—PDF is generated.
Any help is appreciated!
-- Download URLs as PDF documents (Paginated)
-- Created by Christian Grunenberg on Mon Mar 23 2009.
-- Copyright (c) 2009-2014. All rights reserved.
if theSelection is not {} then
show progress indicator "Downloading..." steps (count of theSelection)
set theURL to URL of theRecord
step progress indicator theName
if theURL begins with "http:" or theURL begins with "https:" then
set theParents to parents of theRecord
set theCopy to create PDF document from theURL name theName in (item 1 of theParents) with pagination
repeat with i from 2 to (count of theParents)
replicate record theCopy to (item i of theParents)
set creation date of theCopy to creation date of theRecord
set comment of theCopy to comment of theRecord
set rating of theCopy to rating of theRecord
set label of theCopy to label of theRecord
set state of theCopy to state of theRecord
hide progress indicator
end performSmartRule
