Not sure if I’m doing something stupid here. I have a smart group and get its UUID with Copy item link
from the context menu. I then use the UUID in a small script
set r to get record with uuid "E18BD315-6DD1-4D0F-AFB2-928B750A786F"
and get missing value
. This is the UUID of the “global” smart group “Create version”, if that matters. I’m not sure how to get at this record otherwise, as it’s probably not associated with a Database
object. Or is it?
JFTR: The script doesn’t work either in JavaScript.
