Here is my contribution, while Batch Processing is under arrest )
-- Script to change Custom Meta Data in a Batch
-- Created by Silverstone on 12.11.2019
-- Updated on 23.04.2021
use AppleScript version "2.7"
use application "LNSOSAX"
use application "SatimageOSAX"
use scripting additions
use script "Dialog Toolkit Plus" version "1.1.0"
set theRecords to get selection
if (count of theRecords) > 0 then
-- Setting Up the Dialog
set theTop to 0
set accViewWidth to 400
set theLabelStrings to {"Identifier:", "From:", "To:"}
set maxLabelWidth to max width for labels theLabelStrings
set controlLeft to maxLabelWidth + 8
set {ToField, ToLabel, theTop, fieldLeft} to create side labeled field "" placeholder text "Leave Empty to Delete the Value" left inset 0 bottom (theTop + 12) total width accViewWidth label text (item 3 of theLabelStrings) field left controlLeft
set {FromField, FromLabel, theTop, fieldLeft} to create side labeled field "" placeholder text "Look for Specific Values?" left inset 0 bottom (theTop + 12) total width accViewWidth label text (item 2 of theLabelStrings) field left controlLeft
set {IdentifierField, IdentifierLabel, theTop, fieldLeft} to create side labeled field "" placeholder text "As in DEVONthink Preferences" left inset 0 bottom (theTop + 12) total width accViewWidth label text (item 1 of theLabelStrings) field left controlLeft
-- Window Title and Options Description
set {theRule0, theTop} to create rule (theTop + 20) rule width accViewWidth
set TitleMessage to "You are about to change Custom Meta Data" & linefeed & "for " & (count of theRecords) & " selected Record(s)"
set LabelMessage to "Possible options are as follows:" & linefeed & linefeed & "'From' is not empty and 'To' is not empty:" & linefeed & "Script will replace the Value with 'To' only if it finds the Records with the Value, specified in 'From'" & linefeed & linefeed & "'From' is empty and 'To' is not empty:" & linefeed & "Script will replace the Value with 'To' in All selected Records" & linefeed & linefeed & "'From' is not empty and 'To' is empty:" & linefeed & "Script will delete the Values only if it finds the Records with the Value, specified in 'From'" & linefeed & linefeed & "'From' is empty and 'To' is empty:" & linefeed & "Script will delete the Values in All selected Records" & linefeed & linefeed & "* The format for entering a Date is: 'Day-Month-Year' all in numbers"
set {MainLabel, theTop} to create label LabelMessage bottom theTop + 14 max width accViewWidth control size small size aligns left aligned
set {MainMessage, theTop} to create label TitleMessage bottom theTop + 14 max width accViewWidth aligns center aligned control size large size with bold type
set {theButtons, minWidth} to create buttons {"Cancel", "GO"} default button 2 given «class btns»:2
set allControls to {IdentifierField, IdentifierLabel, FromField, FromLabel, ToField, ToLabel, MainLabel, MainMessage, theRule0}
set {buttonName, controlsResults} to display enhanced window "Batch Change of Custom Meta Data" acc view width accViewWidth acc view height theTop acc view controls allControls buttons theButtons with align cancel button
-- Processing Dialog Results
if buttonName is "GO" then
set {theID, theFrom, theTo} to {item 1, item 3, item 5} of controlsResults
-- Converting String to Date if Date format is detected
set theFrom to my IsTheDate(theFrom)
set theTo to my IsTheDate(theTo)
show progress indicator "Changing Custom Meta Data…" steps (count of theRecords) with cancel button
set theNumber to 0
step progress indicator "(" & (theNumber + 1) & " of " & (count of theRecords) & "): " & ((filename of theRecord) as string)
if theFrom is "" then
if theTo is not "" then
-- Replacing all Selected with 'To'
my SetCustomMD(theID, theTo, theRecord)
else
-- Deleting CMD in All Selected
my DeleteCustomMD(theID, theRecord)
else
-- Setting specified CMD to 'To' if it matches the Search criteria in 'From'
my SetFoundCustomMD(theID, theFrom, theTo, theRecord)
else
-- Deleting specified CMD if it matches the Search criteria in 'From'
my DeleteFoundCustomMD(theID, theFrom, theRecord)
set theNumber to theNumber + 1
hide progress indicator
else
display dialog "Select Items in DEVONthink" with title "No Selection" buttons {"OK"} default button "OK"
on SetCustomMD(theLabel, theValue, theDoc)
tell application id "DNtp" to set theFields to custom meta data of theDoc
theFields
on error number -2753
set theFields to {}
set theField to {}
set theField to set user property ("md" & theLabel) in theField to theValue
set theFields to theField & theFields
set custom meta data of theDoc to {}
set custom meta data of theDoc to theFields
end SetCustomMD
on DeleteCustomMD(theLabel, theDoc)
theFields
set theFields to {}
if theFields is not {} then
set theValue to get user property ("md" & theLabel) in theFields
on error
return
set theFields to delete user property ("md" & theLabel) in theFields
end DeleteCustomMD
-- Setting specified CMD if it matches the Search criteria
on SetFoundCustomMD(theLabel, theSearch, theReplace, theDoc)
theFields
set theFields to {}
set theField to {}
set theFound to get user property ("md" & theLabel) in theFields
on error
return
if theFound is theSearch then
set theField to set user property ("md" & theLabel) in theField to theReplace
end SetFoundCustomMD
on DeleteFoundCustomMD(theLabel, theSearch, theDoc)
theFields
set theFields to {}
on error
return
end DeleteFoundCustomMD
-- Converts the String to the Date if the String was entered in Date format 'day-month-year' (only date part), otherwise returns the input
on IsTheDate(DateString)
set theF to find text "^(?:(?:31(\\/|-|\\.)(?:0?[13578]|1[02]))\\1|(?:(?:29|30)(\\/|-|\\.)(?:0?[13-9]|1[0-2])\\2))(?:(?:1[6-9]|[2-9]\\d)?\\d{2})$|^(?:29(\\/|-|\\.)0?2\\3(?:(?:(?:1[6-9]|[2-9]\\d)?(?:0[48]|[2468][048]|[13579][26])|(?:(?:16|[2468][048]|[3579][26])00))))$|^(?:0?[1-9]|1\\d|2[0-8])(\\/|-|\\.)(?:(?:0?[1-9])|(?:1[0-2]))\\4(?:(?:1[6-9]|[2-9]\\d)?\\d{2})$" in DateString with regexp and all occurrences
if theF is not {} then
set theDate to date DateString
return theDate
else
return DateString
end IsTheDate
