Just purchased DTTG. I thought it would be a good test of the overall product line. As it stands, I can do nothing more than to create txt doc and imported a picture from my library. If anyone can help I would be very thankful.
I received your email, but I’ll respond here since you have asked the question in the forum also. DEVONthink To Go is a companion app to the Mac versions of DEVONthink, so there is little (as you have discovered) that you can do with it as a stand-alone product. If you have not done so already, I would suggest downloading a free trial version of one of the Mac editions and work with the two in tandem to get a feel for how the product line works together.
