This is a vague question about how to keep the automation “stuff” of various units in sync.
I’ve used DT in a very basic way, I got a few simple applescripts for creating notes, but that’s about it. However, I would like to start taking more advantage of the automation features DT offer, and I hope to be able to do a few things this summer.
My problem is that I use 3 Macs, 3 iPads, and one phone and sync my databases between them. I have my syncstore on a webdav server, since I have two completely separate Apple IDs (work/home).
I fully understand that some automation can’t be shared between iOS and macOS, but what is the best way to share automation “stuff” so I can use them on different devices with as little work as possible.
For example: I currently have a few applescripts that I, because of the way I’ve done it, need to be manually move between Macs - which results in different versions on different devices.
What I really would like to have, is the possibility to create/modify automation “stuff” on one device and have it automatically synced to as many of the other devices as possible.
The macOS syncing is the most important, but if things can work on both macOS and iOS I would be very happy.
I write ‘automation “stuff”’ to indicate that I’m not set on using a specific way of doing things, for example: only AppleScript solutions are OK. I’m open for any kind of automation solution (except for using external or local AI solutions).
The automation will be centered around document creation and organization (yep, a very general, fluffy description). The documents are mainly Markdown and PDF documents, screenshots, and some Excel/Word documents. PDFs and Excel/Word files are usually sent to me, while Markdown files are almost 100% created by myself.
Does anyone have any advice for how I should set up my automation solutions in order to make them as easy as possible to sync to various devices?
