WebDav Setup Help
Hey, I’m looking for some assistance with setting up my WebDAV. I’m having trouble getting the Sync Store to appear across my other devices.
Did you read the In & Out > Sync:WebDAV section of the built-in Help and manual?
Thanks, I am using WebDAV on my MacMini. The sync store will not appear in the dropdown when setting it up on other devices.
You need to define what these “other devices”.
MacBook, MacStudio
My experience is that this happens when you have the wrong base WebDAV URL. For example, on my Synology box the WebDAV URL has a /home path like https://myid.synology.me:5006/home, whereas on my VPS I gave it a subdomain and allowed it to store data at the root so it’s just https://webdav.example.com/
What is reported in DEVONthink’s Window > Log?
