I have a problem with the connection of WebDAV.
I have set up sync via WebDAV on my NAS.
But when I enter the connection via https:// and also select the correct port from my NAS for it I always get a connection problem (see screenshot):
I have now changed it first to http://
The problem exists from any terminal device. No matter if desktop or iPhone or iPad.
Can anyone help me why this is so, or what I can change here so that it works again via https://.
Apart, you must set read and write permissions to the shared folder for the user you are connecting to. And open your router to redirect 5005 or 5006 to your NAS IP.
On DTTG iPhone and iPad, the “.manifest” is missed. Then on DT3, when I try to select “check thoroughly/…gründlich überprüfen” storage location with OPT-right mouse button, I get the error message below after a few seconds.
