Weird naming behaviour for duplicates in DT3pro
Hello,
I have duplicated some files from one database to another.
When I rename the file in one database, the original gets renamed as well, which is problematic because I have organised the originals based on file names.
Then, when I renamed the original document in the main database, the duplicate went “missing” (couldn’t be found) in the other database.
I thought the purpose of duplicates was to make multiple copies that wouldnt affect the original, while replicants were supposed to alter one-alter them all.
Am I missing something or is this odd behaviour?
Cheers,
Is this an indexed file?
Yes it is. And just by reading your reply I think that’s the issue. Correct.
One possibility is to duplicate the file first in the original database and to move the copy to the other database afterwards.
thank you!
