Hello DTers. I have a bit of a situation… I have used DT on a macbook for years, and recently installed DTTG on my iphone for note taking.
Well, my macbook fell into the sea and is completely dead. I have replaced it with a new machine, but i dont recall my sync method (location of the DBs, dropbox, or icloud, etc). I do have them however on the iphone, that is, I see the databases, but in DTTG I can’t find the sync location in settings.
Can anyone advise how to ascertain from DTTG where my DBs live?
thank you so much Jim. The thing is, I don’t see any locations, just ‘add’ location (viz screenshot). though in my homescreen i can see DBs but i can’t see ‘where’ they are.
any thoughts? and again, many thanks!
I am ECSTATIC to say that i guessed a location/encryption combination and it worked! dancing on the ceiling right now, i thought i had lost years of notes and work.
So firstly thank you for your helo, and secondly if you can please advise: how do i make sure this never happens again!. can i backup my data? or sync to two places?
Best to read “A Word about Backups” in the “DEVONthink Manual”, page 19.
You should be backing up the DEVONthink databases on the machines on which they reside. Further, you should be backing up the entire machines regularly. Apple TimeMachine does this. TimeMachine will backup the DEVONthink databases residing on the machine.
The sync locations do not need to be backed up. They are files that DEVONthink only uses to sync between machines. Backup the machines with the data, not the sync locations.
As @rmschne mentioned, sync is not a backup and you should be setting up proper backups. We strongly advocate proper primary backups using TimeMachine (or similar snapshot-style backup applications) and external drives. Also, you should read the series of articles we posted:
PS: Don’t forget to scrub those footprints off your ceiling
