I have a folder with lots of old Visual FoxPro type files (VCX, SCX, etc.), but they all have a standard “DBF” type format.
Now, EasyFind, is the ONLY tool that seems to be able to successfully search these files and find search matches. That’s both surprising and a little scary since I cannot find another utility, anywhere, that can do it.
Even something like a $find -d -name **.*" | xargs grep “searchTerm”
Doesn’t find most of the files.
Which brings me to DTPO.
I indexed the same folder that EasyFind has no problems with, but DTPO finds nothing for any of my search terms. Instead, I get a log with a bunch of “unknown” file formats.
Yeah I know, but why don’t you index them (make them searchable) anyway at least? Your own EasyFind knows how to do it.
I’m still looking for the perfect search utility and I wish it were DTPO. However, only the free EasyFind seems to be up to the task of actually searching my files.
(Yes, I know DTPO isn’t a “Spotlight Replacement”, but come on…).
In fairness, even FoxTrot Professional Search, which does create indexes also found NOTHING in my search folder.
I hope a future version of DTPO will be more robust and actually index all the files…or that a future version of EasyFind will also index and, not only find all files as it does now, but be much faster.
Thanks,
- m
