I use square bracket notation for wikilinks ([[something]]
). It seems that in my DEVONthink 3.9 on macOS 10.15, the completion of documents when I start typing [[
does not take into consideration aliases. If I have a document named foo
and it has an alias bar
, then after typing [[b
, I don’t get a completion for bar
, but I do get a completion for foo
if I start typing [[f
Is it supposed to work for aliases too? If so, is there a setting that controls the behavior? Maybe I changed something long ago and forgot all about it …
