Very diplomatic @chrillek
/bites tongue
/curses under breath
Bookmarked and copied to a Markdown doc in DEVONthink. Great stuff!
Backups: sigh. Why are the things we Have To Do so boring (rhetorical ??). So I use Time Machine to back up occasionally to a big old hard drive. And I have critical things I’m currently working on sitting in iCloud. And I have Backblaze. So I’ve made it as easy as possible and it seems to be working fine – and when four drops of clean water on the keyboard fried my MacBookPro logic board, I was very, very grateful to have them. My question for the group: Arq? As is my wont, I looked up most recent reviews and Arq doesn’t do very well. And nobody here mentioned Backblaze (which I learned about here), which gets very good reviews. Something I’ve missed?
Can you post a link to those reviews
I needed a cloud version of Time Machine, and committed to a year with Arq Premium
So far (2 weeks), the results look good
I think Arq had some problems when version 7 came out. I’m using it regularly (also to backup to Blaze), and have no complaints.
But (big but!): I didn’t have to restore anything yet. Not drinking while working…
what does it cost to loose a week of work?
I’ve used Arq and Backblaze in the past. I dropped Backblaze a while ago.
Arq had issues with version 6. Version 5 and 7 never caused issues for me. Restores work as expected.
Backblaze spends a lot on marketing, but their software quality seems to have an amateurish touch (bugs, longstanding security issues, questionable design decisions and other things giving them a really bad look) that several people/engineers highlighted while I was looking on Twitter and Hackernews a while back (examples linked in the comment below):
In addition to those issues, they don’t really back up all your data:
Here is a comment quoting Backblaze themselves on this:
Encrypted DT databases can’t be backed up unless open.
Some other issues I encountered while using Backblaze:
In comparison, Arq has better features:
I’m a week behind you with Arq Premium but agree with your assessment (just in case it assists others here).
Stephen
No, Arq deduplicates data and will only upload the changes.
Just be aware that Wasabi has a 90 day minimum storage time requirement. So you might make your backups immutable for 90 days (instead of 30) because you are paying for it anyway, even if you delete something earlier.
I just read that and wanted to summarize some points, @winmker
Your proposed idea works perfectly fine!
But it is a bit lacking … so let’s add some generic information:
A good advice is, to have 2 local and 1 remote “current” copies of your data.
Of course, TimeMachine can be used for the second local copy.
Wether that should be done automatically or manually depends on your needs and type of data, also the rate of change to your data.
In general, new backups are only required when something important got added or changed. That’s your decision.
And then, you should also have at least one older backup, an archive - in case things go bad.
If your remote solution is OneDrive or Dropbox, this also protects against ransomware or similar problems, because they can also act as archive - restoring older versions of you data from their versioning.
I am not sure about iCloud in this regard, but read that this is not fully possible - only for “documents”.
So, in such a case, you should archive data yourself, meaning that you hold and rotate older backups.
Again, such archives could just be additional and older local backups, but if the amount of data allows for this, it is good to (also) have them in a remote location.
That’s it.
And in case of DEVONthink, you often already added a remote sync location, which solves the “remote current copy” automatically.
So, with your manual backup, you are already quite secure.
The only thing missing is, that you should hold some older archives and rotate them from time to time. At best local and on a remote location.
