I added some new features and adapted it to a smart rule.
Script
use script "RegexAndStuffLib"
use scripting additions
set Path_A to false
set Path_B to false
set n to (count selection)
if n = 1 then set Path_A to true
if n > 1 then set Path_B to true
if Path_A then
set theRecord to (content record of think window 1)
set theDB to the database of theRecord
set theMainText to the plain text of theRecord
if theMainText contains "<!-- " then
set theFiles to regex search theMainText search pattern "\\<!-- \\{\\{(.+)\\.md\\}\\} -->" -- look for commented out transclusion marks
repeat with theFile in theFiles
set theReplaceTemplate to my replacetext(theFile, "<!-- ", "") -- reverse to uncommented
set theReplaceTemplate to my replacetext(theReplaceTemplate, " -->", "") -- reverse to uncommented
set theSearchPattern to my replacetext(theFile, "{", "\\{") -- Prepare to look for the commented mark using regex
set theSearchPattern to my replacetext(theSearchPattern, "}", "\\}") -- Prepare to look for the commented mark using regex
set theSearchPattern to my replacetext(theSearchPattern, "|", "\\|") -- Prepare to look for the commented mark using regex
set theSearchPattern to theSearchPattern & "(.|\\s)+?\\*\\*\\*" -- Search pattern including transclusion mark and transcluded text
set theMainText to regex change theMainText search pattern theSearchPattern replace template theReplaceTemplate
set theFiles to regex search theMainText search pattern "^\\{\\{(.+)\\.md\\}\\}"
if theFiles is not {} then
--set theFile to item 1 of theFiles
set theSubName to ""
set theSearch to ""
set theSubText to ""
set theSubRecord to ""
set theReplacement to ""
set theSection to ""
set theSearchName to my replacetext(theFile, "{{", "")
set theSearchName to my replacetext(theSearchName, ".md}}", "")
if theSearchName contains "|" then
try -- parse variable
set oldDelims to AppleScript's text item delimiters -- salvar o delimitador padrão
set AppleScript's text item delimiters to {"|"}
set theText to theSearchName
set delimitedList to every text item of theText
set AppleScript's text item delimiters to oldDelims -- restaurar delimitador padrão
on error
set AppleScript's text item delimiters to oldDelims -- restaurar delimitador padrão em caso de erro
set theSection to item 1 of delimitedList
set theSearchName to item 2 of delimitedList
set theSearch to search "name:\"" & theSearchName & "\"" in theDB
if theSearch is not {} then
set theSubRecord to the item 1 of theSearch
set theSubText to the plain text of theSubRecord
if theSection is not "" then
set n to (count my decoupe(theSection, "#")) - 1
set theSectionSearch to theSection & "((.|\\s)+)" & "(#{" & n & "}|\\*\\*\\*)"
set theSectionText to regex search theSubText search pattern theSectionSearch replace template "$1"
set theSectionText to my replacetext(theSectionText, "***", "")
set theSubText to theSectionText
set theSubText to regex change theSubText search pattern "(aliases: .+)" replace template ""
set theSubText to regex change theSubText search pattern "(tags: .+)" replace template ""
set theSubURL to the reference URL of theSubRecord
set theSubURL to "<div style=\"text-align: center\"><a href=\"" & theSubURL & "?reveal=1\">[Edit section]" & "</a></div> "
-- Randomize footnotes
set theSubText to my replacetext(theSubText, "[^1]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^2]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^3]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^4]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^5]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^6]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^7]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^8]", "[^" & (random number 100) & "]")
set theSubText to my replacetext(theSubText, "[^9]", "[^" & (random number 100) & "]")
-- end randomize
-- set theSign to "\\* \\* \\*"
set theSign to "---"
-- set theSign to "```" & return & theSearchName & return & "```" & return
set theReplacement to "<!-- " & theFile & " -->" & return & return & theSign & return & theSubText & " " & return & theSubURL & return & return & "***"
set theMainText to my replacetext(theMainText, theFile, theReplacement)
set theSearch to ""
on error
set theSubURL to "<sup>[\\[Edit subsection\\]](" & theSubURL & "?reveal=1)</sup> "
set theMainText to my replacetext(theMainText, "[^1]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^2]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^3]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^4]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^5]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^6]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^7]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^8]", "[^" & (random number 100) & "]")
set theMainText to my replacetext(theMainText, "[^9]", "[^" & (random number 100) & "]")
-- end randomize
set theReplacement to "<!-- " & theFile & " -->" & return & return & theSubText & " " & theSubURL & return
set theMainText to my replacetext(theMainText, "-->
set the plain text of theRecord to theMainText
if Path_B then
set theRecords to the selection
set theSearch to ""
on error
-- end randomize
set theSearch to ""
on error
-- end randomize
end performSmartRule
on replacetext(theString, old, new)
set {TID, text item delimiters} to {text item delimiters, old}
set theStringItems to text items of theString
set text item delimiters to new
set theString to theStringItems as text
set text item delimiters to TID
return theString
end replacetext
on decoupe(t, d)
local oTIDs, l
set {oTIDs, AppleScript's text item delimiters} to {AppleScript's text item delimiters, d}
set l to text items of t
set AppleScript's text item delimiters to oTIDs
return l
end decoupe
