I am trying to create a smart rule that will append the name and link of a document in a specific folder into a note in Agenda. I have to use agenda’s url scheme to update the specified note. I have an applescript that mostly works, but I cannot figure out how to URL encode (there can be spaces in the document name, so these need to be URL encoded).
Does anyone have any experience with url encoding in AppleScript? Or does anyone have a better way of doing this? (basically I am just updating a list of invoices that need to be paid as I receive them, so as invoices appear in my invoices folder Agenda will be updated with a list of what has been added in the folder)
set theText to "hallo welt überall"
set theText_encoded to my urlEncode(theText)
on urlEncode(str)
local str
return (do shell script "/bin/echo " & quoted form of str & ¬
" | perl -MURI::Escape -lne 'print uri_escape($_)'")
on error eMsg number eNum
error "Can't urlEncode: " & eMsg number eNum
end urlEncode
use framework "Foundation"
on urlEncode(str)
local nsStr
set nsStr to current application's NSString's stringWithString:(str)
set characterSet to current application's NSCharacterSet's URLQueryAllowedCharacterSet()
return (nsStr's stringByAddingPercentEncodingWithAllowedCharacters:characterSet) as text
end urlEncode
Thank you @pete31 and @cgrunenberg. Those both look useful, but I cannot get either to work. I don’t expect anyone to troubleshoot my novice attempts at applescript, but if you see an obvious rookie mistake here, I’d be interested to hear what it is.
set the comment of theRecord to "x-devonthink-item://" & uuid of theRecord
set agendaNote to "agenda://x-callback-url/append-to-note?identifier=8DE495E1-6F45-41E0-9D34-30960408B0F4&text=" & "[" & uuid of theRecord & "]" & "(" & "x-devonthink-item://" & uuid of theRecord & ")"
display dialog (display dialog agendaNote)
set theURL to urlEncode(agendaNote)
display dialog theURL
open location theURL
end performSmartRule
on urlEncode(str)
local str
end urlEncode
The rule runs, but nothing seems to happen after display dialog (display dialog agendaNote)
set recordURL to reference URL of theRecord
-- The UUID is the alphanumeric portion of the reference URL
-- The rererence URL is the entire item link
set recordName to name of theRecord
-- Get the name of the record
set the comment of theRecord to recordURL
-- Set the comment of the record to the item link
set agendaNote to "agenda://x-callback-url/append-to-note?identifier=D5F1A1A4-D77D-4AE2-95CC-708AA6F1A006&text=" & "[" & (my urlencode(recordName)) & "](" & recordURL & ")"
-- The recordName is passed to the URLEncode handler
open location agendaNote
on urlencode(str)
local str
end urlencode
Note: I would get in the habit of adding comments to your code, especially as you’re thinking through something. Actually, a pen and pad of paper is a fantastic set of tools for scripting.
May I add that URI::Encode is not necessarily available? At least on my Big Sur installation, it does not exist.
If the whole thing doesn’t have to work in a smart rule, I could try to provide a JavaScript version. It provides a built-in method to encode URIs.
Do you mean MURI::Escape? Or am I overlooking a reference to URI::Encode in Jim’s script?
@bangersandmash from what you’ve posted I can’t see any obvious reason - would you post the whole script you are using - or is it exactly cut&paste from what Jim posted?
perl -MURI::Escape
tells the Perl interpreter to load the M odule (hence -M) URI::Escape. So: No, I mean URI::Escape. If you’re still on Catalina, give it a try:
ja, but you wrote URI::Encode, so I was confused (and see my next post, maybe you were too but thanks for the -M info - it’s little things like that which make it clear I’ve not got a clue )
Yeah, I tried that, had the same problem and posted the solution a couple of posts up. You might have missed that, because I went a little OT, which is why I’m pointing you to the solution again.
Thanks everyone, for your help. I can’t explain how, or why, but this is what finally worked (urlencode has to go first, for some reason):
on urlencode(str)
local str
end urlencode
set agendaNote to "agenda://x-callback-url/append-to-note?identifier=8DE495E1-6F45-41E0-9D34-30960408B0F4&text=" & "[" & (my urlencode(recordName)) & "](" & recordURL & ")"
