I am trying to come up with a script to create a nested tag from #parent tag/child tag. But I am still appleccript stupid, so forgive me for this next question.
set theResult to extract keywords from record [record] ¬
barcodes [boolean] ¬
existing tags [boolean] ¬
hash tags [boolean] ¬
This was taken from DT3 AS dictionary. How should this read into an actual script where I want to extract hash tags?
When tagging via AppleScript, how can I use one tag as parent and the other one as child?
This command returns only found & preprocessed tags, therefore it’s not suitable to create nested tags. Subtags can be e.g. created like this:
set theDB to current database
set theTag to create location "/Tags/ParentTag" in theDB
set theSubtag to create location "/Tags/ParentTag/Subtag" in theDB
You’re awesome, Chris @cgrunenberg. DT3 is getting dangerously close of becoming a mad mean wikifying machine
Easy to create new md files from selection
Auto nested tags via smart rule
-- Go through each record
set selectedItems to selection
repeat with theRecord in selectedItems
-- Get the text of the record (assuming text/markdown file)
set _text to plain text of theRecord
-- Use shell script to extract text after character "#", ending with a space/new-line etc
-- UPDATED search line v2, take care of hashtags in web links, we dont want their # in the link as tags..
set grepResults to do shell script "grep -E -o " & quote & "(\\s|^)#\\S*" & quote & " <<< " & quoted form of _text & ¬
"| sed -E " & quote & "s/#//g" & quote
-- Clear the current records tag list
set tags of theRecord to {}
-- transform the output to a list
set grepResultsList to paragraphs of grepResults
-- Add found tags one by one
repeat with fTag in grepResultsList
set fTagString to fTag as string
-- If the tag is an empty string (likely a # without text afterwards, like markdown header, skip it)
if fTagString is not "" then
if fTagString does not contain "/" then
-- Add this tag to the records tag list
set tags of theRecord to tags of theRecord & fTagString
if fTagString contains "/" then
set {od, AppleScript's text item delimiters} to {AppleScript's text item delimiters, "/"}
set theTags to text items of fTagString
set theTag1 to the item 1 of theTags
set theTag2 to the item 2 of theTags
set theTag1 to create location "/Tags/" & theTag1 & "/" & theTag2 in theDB
set tags of theRecord to tags of theRecord & theTag2
end performSmartRule
This script from the other thread and added the ability to created nested tags with #parent/child. Thanks for sharing the script, @Magicnemo.
In case anyone else is reading this: some improvements is still needed for allowing spaces in tags and nesting with more levels (currently only parent/child work).
Obsolete tags automatically deleted
I am also using the filter obsolete tags smart rule.
Last, but not least: keyboard navigation to other md files
tell application "System Events" to set frontApp to name of first process whose frontmost is true
tell application process frontApp
set _selection to value of attribute "AXFocusedUIElement"
tell _selection to perform action "AXShowMenu"
@cgrunenberg, if I want the shortcut for this to be ⇧⌘L, how must ⇧ appear in the file name for this to work? Sure I can use MacOS to set it up, but I am curious about using this method you suggested in the other thread.
The order shouldn’t matter but this shortcut is actually already used (see Format menu). BTW: Here’s a revised & simplified version of your script as smart rule scripts shouldn’t process the selection. In addition, this script supports deeper nesting like #just/a/test
-- UPDATED search line v2, take care of hashtags in web links, we don't want their # in the link as tags..
set grepResults to do shell script "grep -E -o " & quote & "(\\s|^)#\\S*" & quote & " <<< " & quoted form of _text & "| sed -E " & quote & "s/#//g" & quote
set od to text item delimiters of AppleScript
set text item delimiters of AppleScript to return
set grepResultsList to text items of grepResults
set text item delimiters of AppleScript to od
if fTag is not "" then
set theTag to create location "/Tags/" & fTag in (database of theRecord)
replicate record theRecord to theTag -- Replicating is tagging (and vice versa)
