Convert imported to indexed and keep replications
Hi,
I’ve been using DTPro as imported databases for many years.
I also look after my parents’ docs in one of those imported databases. The problem with this is that they cannot access any of it.
Q1: Is the following scenario a safe one?
  • Convert my parents’ Db to an indexed one with the location (of the indexed files, not the Db) being an iCloud folder that is shared with my parents’.
  • The files themselves are visible to them but my DT DB remains firmly on my Mac (but synced to DTTG).
  • the shared folder is read-only to my parents’ to ensure nothing weird happens by accident.
Q2: Is the best way to convert from imported to indexed without losing replications still the following?
  1. Add an empty indexed folder to my existing Db
  2. Move my (imported) groups across to that indexed folder
Thank you,
Yes, your Q2 is the recommended method if you want to maintain item links, already added metadata, etc.
Thanks. Is it OK to have my indexed files in iCloud though?
I wouldn’t think there would be an issue. I cannot recall ever having indexed folders in iCloud but my primary database for many years was an indexed set of folders in OneDrive. There are some horror stories about indexing mishaps in this forum, though I never ran into any major issues myself. Good luck.
Yes, but you should read and understand the In & Out > Importing & Indexing section of the built-in Help and manual, if you haven’t already.
If you were trying to do quick updates between yours and their Mac, I would be less supportive since iCloud can and occasionally does stall. But if there are no time-sensitive documents you’re trying to push to them, it will likely work okay.
Only thing I would add, from my experience (and probably covered in the manual section @BLUEFROG highlighted) is to make sure the folder(s) on iCloud are set to be always on your computer. Otherwise DT will try to redownload any whisked off to iCloud only. This can cause a delay if lots have been moved into the cloud when you open the group in DT.
And just a side note for DEVONthink 4…
Thanks all!
well, I have just:
  • created a shared iCloud folder (with my mum - she’s read only).
  • My iCloud was already set to ‘keep everything’ (for backup purposes)
  • created an indexed folder in DTP
  • moved everything across from imported to the indexed folder
  • links and replicants are all still there and mum can see everything (not that she will, but she can).
Brilliant!
DTP never creases to amaze me. I only use the Pro version because of the Fujitsu scanner integration but it’s so worth it.
Excellent! :heart:
Follow up question for understanding (apologies if this is in the docs).
As an example, I have a file replicated across different groups in my imported database. When moving them to indexed, how does DTP know which is the master/real file to copy across (as replicants aren’t real so don’t actually get copied)?
…is there a way I can see where that real file is first so I can ensure it is in the right group before moving it to indexed?
…hope that makes sense.
Anyone?
You said it yourself – there is no “real” file with replicants, they are all the same. Or rather pointers to the same. And yes, that’s on the documentation.
The only thing that is “real” about replicants IDs their path, and that’s identical for all of them.
I think what you’re trying to ask is this:
If you convert imported files and groups to indexed files and folders, how does DEVONthink handle replicated files in that process?
Does it:
a) make a COPY of each replication in every DT group to the new Finder folders?
b) make an alias in some places?
c) do something clever that’s neither of a or b?
d) can you chose what happens in this particular instance
I don’t work with indexed files to that extent so I can’t answer your question. But you could do a test and make a bunch of dummy groups and replicate a test document in those groups and convert it to indexed files. That’s what I would do. Test. Test. Test. Always test.
Hi both,
Thanks, but you both misunderstood my question.
I am transferring my entire imported database to indexed.
In doing so, one of each replicated file must become real in the indexed file system. Can you tell which one will become real before you transfer?
The answer is (c) - one of the replicants becomes real.
I assume it was the original one before it was replicated to begin with …but how can you tell where that original is in the imported database?
As @chrillek mentioned, There is no ‘original’ file. As far as DT is concerned they’re all exactly the same. This particular quirk of computery shenanigans doesn’t have a good analog in the real world, at least not one that holds up under scrutiny. Suffice to say that DT doesn’t consider any of the replicants as different or more important than any other. No “original”, no “created first”, no “degraded 2nd generation clone”, nuthin!
If, as you discovered by testing, that only one of them becomes real, what is in the other newly indexed locations where the replicants were?
An alias?
Nothing?
Do tell.
Sorry, I thought I had explained this - I’m not doing a good job at this.
  • One of them was real before it was replicated.
  • Only one of the replicants becomes real in the filing system (the others don’t exist).
I assume that the one that becomes real was the original one before it was replicated. …but how to tell which one that is?
You can’t unless you remember it specifically.
Got it, thanks @BLUEFROG
