Devonthink web clipping saving as bookmark instead of PDF
On February 23rd, 2023, I submitted a ticket (#343596) which has an example there.
The issue happens with almost much any URL I save, and works fine on the 2nd attempt, as @cyounkins also described.
At the time I created the ticket I was on Ventura, and now I am on Sonoma.
I clip using the browser extension, mainly on Safari. Sometimes I clip with Chrome too, but I don’t remember if I have observed this issue there.
After restarting DEVONthink 2 days ago, it’s been working fine on the 1st attempt for a few pages that I have tried. But I’m sure it will certainly start happening again.
It seems that DEVONthink enters some strange state that prevents it from saving it correctly on the 1st attempt.
Sometimes I do that too. Other times I use File > Export as PDF, which can also be nice if the page isn’t too long (because it produces a single-page PDF).
Thanks for the advice.
Safari’s Export as PDF feature seems to work every time for me. Not sure why I didn’t try it before, and just kept clipping webpages multiple times with the DT extension.
I opened a webpage, used File > Export as PDF, and saved it to the Inbox folder that imports into DT; PDF saved, and imported into DT as expected (yes, I checked the PDF for content).
Just for fun, I tried the same webpage with the Clip to DEVONthink extension, but things didn’t go so well, resulting in DT clipping a .webloc file instead of a PDF. I then tried using the clipping extension a second time, and DT correctly clipped and imported the page as a PDF (expected behavior, it always works the second time, but having to clip twice is kind of annoying).
Hi, @rigz . Thank you your sharing your thoughts. Sometimes I use Safari’s Export as PDF, too.
However, the PDF it produces is a single-page, which means that the longer the original page is, the more you have to zoom in when you open the file.
In some cases it’s OK. In others, it’s just better to export the content in multiple pages and not having to zoom to be able to read.
Also, note that the PDF produced using Safari’s method is normally larger in size.
Since, i think for years, i have to live with this issue.
I never get a pdf, even after a restart.
Today: Mac OS 18.5, Devonthink 3.9.10
Wenn i try, for example, to get a pdf of THIS DT.support-Webpage, using this command:
i confirm with “PDF-Hinzufügen”:
And the result in Devonthink is not the expected .pdf but a .webloc
Devonthink pdf-problem 3
As i can read above, you seem not to be able to reproduce this behavior, but it is for years a realy annoying Problem in my usage of Devonthink.
Any new ideas to solve this Problem?
Usage of browser extensions or directly opening the Web Clip tab of the Sorter is highly recommended, DEVONthink’s sharing extension basically receives no useful information from browsers. Only the URL.
Which “Browser Extension” would you recommend to give me PDFs of Webpages to save them in Devonthink?.
I thought DEVONthink’s sharing extension IS a “Browser Extension”?
What or where is the “Sorter” in Safari?
That’s a generic extension available in most apps, browser extensions are only available for Safari, Chrome & Firefox.
