For no apparent reason, I am unable to edit existing smart groups. I can create new smart groups and they work, but I can’t edit them. For years, I have Cntrl+right click with no issue. I have tried editing using my different databases and the global nbox but the issue persists.
I have DT3 on the same account but as a rule I do not experiment with DT3 whilst DTPO is open, also I do not open DTPO databases in DT3. The other day I inadvertently had both DTs open but quit DTPO the moment I noticed. I can’t say for certain there was no issue with the smart groups in DTPO after that but I don’t think so.
The only major change I have made to a DTPO database (“A”) is to move dozens of groups to another database (“B”) whilst leaving the smart groups on A. But as A has a group for all items and the smart groups get from that, why would that make a difference?
I have run Verify & Repair but to no avail. I have created a new database and added an item and a smart group but the same problem persists.
And after choosing “Edit…” in the contextual menu nothing happens? In that case please please choose Help > Report Bug while pressing the Alt modifier key and send the result to cgrunenberg - at - devon-technologies.com - thanks!
I could’ve done that direct! But it hasn’t done. All it did was ‘take’ me from DTPO to Mail. Would you like me to reiterate what I said in my op and email that?
I note that DT 3.0beta5 has done something to the global inbox so would it help if I were to uninstall DT3? If so then how do I do that. It’s the beta version, I haven’t upgraded as such to DT3.
I’ll try again now but yes. At the end of my day I quit all apps, delete unwanted cookies and html storage files before switching off. I’ve done all that twice since the problem arose.
The only oddity was a warning that popped up to say something like Non-responsive DNS server or invalid DNS configuration. I checked my network settings (I have a networked printer/copier/scanner) but nothing else. All in order. Never had that before: I wonder if a virus has crept in: I don’t have firewalls. Everything else is working ok.
