Script: Comfortably developing a Smart Rule Script
Developing a Smart Rule script can be challenging:
  • If we use an embedded script then changes are updated immediately - but it’s necessary to open the Smart Rule script editor for each edit. I almost never edit directly in DEVONthink’s editor but copy paste into Script Debugger which makes the process even more cumbersome.
  • If we use an external script then changes are not updated immediately. DEVONthink caches scripts which makes it necessary to restart the app after each edit.
  • If we’re building a Smart Rule that uses an Execute script action and other actions testing might become very difficult.
Scenario 1
Simple Smart Rules
For simple Smart Rules that only use an Execute script action it’s sufficient to call the handler on the selection. That’s also sufficient if a script doesn’t rely on changes made by other actions.
This way we can use an external editor and changes are updated immediately.
-- Developing a Smart Rule Script - External script that calls the handler
on run
	tell application id "DNtp" to my performSmartRule(selection as list)
end run
			activate
				display dialog "Changes are updated immediately"
			return
end performSmartRule
Scenario 2
Advanced Smart Rules
If we’re building a Smart Rule that uses an Execute script action and other actions we might run into a situation where the Smart Rule Script can’t be tested on it’s own because it depends on changes made by other actions.
However, in such a situation there’s a quite comfortable way to develop a Smart Rule script: While developing we can use an embedded script that loads an external script.
This way we can use an external editor, changes are updated immediately and we can test the whole Smart Rule with the changed script.
Setup
1 - External script
In Script Editor.app:
  • Save this script
    Note: It’s not necessary to save it to DEVONthink’s Smart Rule folder.
on developSmartRuleScript(theRecords)
			activate
			return
end developSmartRuleScript
2 - Embedded script
In DEVONthink:
  • Create a Execute script > Embedded action
  • Paste this script
  • Don’t close the editor
In Finder:
  • Go to the external script file
  • Right click it while pressing ⌥
  • Choose Copy as Pathname
In DEVONthink:
  • Set property theScriptPath to the copied path
-- Developing a Smart Rule Script - Embedded Smart Rule script that loads the external script
property theScriptPath : "/Users/USER/Desktop/Test Smart Rule Script.scpt"
			set theScript to load script (POSIX file theScriptPath as alias)
			theScript's developSmartRuleScript(theRecords)
			return
Usage
  • Develop your Smart Rule Script in the editor of your choice.
  • Once everything is working as desired:
    • Scenario 1:
      • Use the script as an embedded or as an external script.
    • Scenario 2:
      • Copy the code inside the developSmartRuleScript handler
      • Paste it in an embedded or in an external script.
        Note: Make sure to copy only what’s inside the developSmartRuleScript handler and paste it into an actual performSmartRule handler.
This is a great idea.
There are a few tiny obstacles to get over when you’re teaching yourself scripting and one of them is that cacheing issue.
I’m sure anyone who started down this path has run into the situation where you run the script from Script Editor or Script Debugger and it’s all fine and then when you try to turn it into a smart rule something steps working and all the changes you make have no impact and eventually you give up after an hour of fruitless googling.
I knew there was a cacheing issue with scripts but it takes a while for the newly formed domains of information to link up in a way that’s useful so you know WHAT to google to find out HOW to do something. Thanks again.
I wish I had reviewed the instructions for Scenario 2 before debugging a Smart Rule-based script over the weekend! I saw DEVONthink’s lovely “Welcome to DEVONthink 3” startup window far too many times…
In case it helps others, I built out a little script to create test files in order to test my Smart Rule-based script.
  1. Modify the below script such that the created file’s properties will cause your script to trigger.
  2. Insert the name of your Smart Rule in line ten, in place of “YOUR SMART RULE NAME” (perform smart rule "YOUR SMART RULE NAME")
my createDemoFiles()
on createDemoFiles()
		set theDestination to get record with uuid "9C204305-52CB-43DB-BC0C-44361880B8B4"
		set dateString to (current date) as text
		set theRecord to create PDF document from "https://fulcra.design/files/_Kudoz-Where-are-you-scaling-placemat.pdf" in theDestination name dateString
		set tags of theRecord to theRecord's tags & ".to-organize" & "News"
		delay 1
end createDemoFiles
Your explanation “DEVONthink caches scripts which makes it necessary to restart the app after each edit” made my day. I’ve been struggling for hours with a script that I couldn’t get to work but now I realize that DT had my first (incorrect) version in cache all the time.
After restart it worked perfectly.
Many thanks!
I use Scenario 1. Just a Simple Smart Rule. No other action. Just Apply Script, External.
I test out by using the exact script. Just change the display dialog text. Save the script external using Script Debugger.
Try to apply the rule. It didn’t pick up the change. If exit and restart DT4, the change takes effect.
I’m feeling kinda dumb.
I’ve never created a smart rule that uses the “Apply Script” action.
If I understand the point of your post, your purpose is to get around having to re-launch DEVONthink when you change a script that’s used by a smart rule?
Perhaps because I haven’t tried a smart rule that uses the “Apply Script” action, to me it’s not apparent how to use either of the two scripts you offer in your post.
Can you give me an example of a smart rule that would show how I’d find these useful?
  1. Create a smart rule.
  2. Add an Apply Script action.
  3. Leave the parameter as External then browse the available scripts in the code popup.
If you don’t have a use for that, why would you? OTOH, there are some tasks that a script can do better than (a bunch of) smart groups. You’ll find a lot of examples in this forum if you search for on perform smart rule (AppleScript) or function performsmartrue (JavaScript).
