This script
- converts records to bookmarks,
- saves the record’s text in the bookmark’s comment
- inherits properties (e.g. comment, tags, label)
By storing the text in the comment we get a “searchable” bookmark, i.e. a search for the original record’s text yields the bookmark.
Note:
- URLs can become unreachable. Do not rely on bookmarks for important things.
-- Convert record to bookmark, save record's text in bookmark's comment and inherit properties
-- Note: URLs can become unreachable. Do not rely on bookmarks for important things
-- This script lets the bookmark inherit properties of the selected record (e.g. comment, tags, label)
-- If you don't want to inherit a property prefix the line with #
property useRedirectedURL : true -- Use redirected URL instead of original record's URL
property markerForUnavailableURL : "--- URL NOT REACHABLE ---" -- Set some string that should be added to the bookmark's name in case it is unreachable. Use this to search for (temporarily) unreachable URLs
if theRecords = {} then error "Please select some records"
show progress indicator "Creating bookmark..." steps (count theRecords) as string with cancel button
set thisRecord_Name to name without extension of thisRecord
step progress indicator thisRecord_Name
set thisRecord_URL to URL of thisRecord
if thisRecord_URL ≠ "" then
set thisRecord_URL_redirected to do shell script "/usr/bin/curl -Ls -o /dev/null -w %{url_effective} " & quoted form of thisRecord_URL
if useRedirectedURL = true then set thisRecord_URL to thisRecord_URL_redirected
on error
set thisRecord_Name to thisRecord_Name & space & markerForUnavailableURL
set thisBookmark to create record with {name:thisRecord_Name, type:bookmark, URL:thisRecord_URL} in (first parent of thisRecord whose location does not start with "/Tags/")
set comment of thisBookmark to my tid({comment of thisRecord, plain text of thisRecord}, linefeed & linefeed & "---" & linefeed & linefeed)
tell thisBookmark -- Inherit properties
set aliases to aliases of thisRecord -- Wiki aliases
set creation date to creation date of thisRecord -- The creation date
set custom meta data to custom meta data of thisRecord -- User-defined metadata of a record
set exclude from search to exclude from search of thisRecord -- Exclude record from searching.
set exclude from see also to exclude from see also of thisRecord -- Exclude record from see also.
set exclude from Wiki linking to exclude from Wiki linking of thisRecord -- Exclude record from automatic Wiki linking.
set label to label of thisRecord -- Index of label (0-7)
set locking to locking of thisRecord -- The locking
set rating to rating of thisRecord -- Rating (0-5)
set state to state of thisRecord -- The state/flag
set tags to tags of thisRecord -- The tags
set thumbnail to thumbnail of thisRecord -- The thumbnail
set unread to unread of thisRecord -- The unread flag
hide progress indicator
return
on tid(theInput, theDelimiter)
set AppleScript's text item delimiters to theDelimiter
if class of theInput = text then
set theOutput to text items of theInput
else if class of theInput = list then
set theOutput to theInput as text
return theOutput
end tid
