This script copies a RTF and a Markdown link of selected records’ names and Reference URLs.
- Depending on the receiving app there’s either the RTF or the Markdown version pasted.
- On pasting RTF links automatically adopt the current app’s font and font size.
Properties
revealRecord: reveal record in database (instead of opening a new document window)includeSuffix: include the record’s suffix
-- Copy RTF and Markdown link
use AppleScript version "2.4"
use framework "Foundation"
use framework "AppKit"
use scripting additions
property revealRecord : true
property includeSuffix : true
if theRecords = {} then error "Nothing selected."
set theReferenceURLs to {}
set theNames to {}
set end of theReferenceURLs to reference URL of thisRecord
if includeSuffix then
set end of theNames to filename of thisRecord
else
set end of theNames to name without extension of thisRecord
my copyRTFandMarkdownLink(theReferenceURLs, theNames)
if the error_number is not -128 then display alert "DEVONthink" message error_message as warningh
return
on copyRTFandMarkdownLink(theURLs, theNames)
set theURLsArray to current application's NSMutableArray's arrayWithArray:theURLs
set theNamesArray to current application's NSArray's arrayWithArray:theNames
if revealRecord = true then
repeat with i from 0 to ((theURLsArray's |count|()) - 1)
set thisURLString to (theURLsArray's objectAtIndex:i)
if (thisURLString's hasPrefix:"x-devonthink") then (theURLsArray's replaceObjectAtIndex:i withObject:(thisURLString's stringByAppendingString:"&?reveal=1"))
if theURLsArray's |count|() = 1 then
set theTypesArray to current application's NSArray's arrayWithArray:{"public.utf8-plain-text", "dyn.ah62d4rv4gu8yc6durvwwaznwmuuha2pxsvw0e55bsmwca7d3sbwu", ¬
"public.url-name", "dyn.ah62d4rv4gu8zs3pcnzme2641rf4guzdmsv0gn64uqm10c6xenv61a3k", "public.url"}
else
set theTypesArray to current application's NSArray's arrayWithArray:{"public.utf8-plain-text", "dyn.ah62d4rv4gu8zs3pcnzme2641rf4guzdmsv0gn64uqm10c6xenv61a3k"}
set thePasteboard to current application's NSPasteboard's generalPasteboard()
thePasteboard's declareTypes:theTypesArray owner:(missing value)
set thePasteboardItem to (thePasteboard's pasteboardItems())'s objectAtIndex:0
repeat with i from 0 to ((theTypesArray's |count|()) - 1)
set thisType to (theTypesArray's objectAtIndex:i)
if (thisType's isEqualTo:"public.utf8-plain-text") then
set theMarkdownLinksArray to (current application's NSMutableArray's arrayWithArray:{})
set theURLsArrayCount to (theURLsArray's |count|())
repeat with i from 0 to (theURLsArrayCount - 1)
set thisMarkdownLink to (current application's NSString's stringWithFormat_("[%@](%@)", theNamesArray's objectAtIndex:i, theURLsArray's objectAtIndex:i))
if i < (theURLsArrayCount - 1) then set thisMarkdownLink to (thisMarkdownLink's stringByAppendingString:(space & space))
(theMarkdownLinksArray's addObject:thisMarkdownLink)
(thePasteboardItem's setString:(theMarkdownLinksArray's componentsJoinedByString:linefeed) forType:thisType)
else if (thisType's isEqualTo:"dyn.ah62d4rv4gu8yc6durvwwaznwmuuha2pxsvw0e55bsmwca7d3sbwu") then
(thePasteboardItem's setData:(current application's NSPropertyListSerialization's dataWithPropertyList:theURLsArray ¬
format:(current application's NSPropertyListXMLFormat_v1_0) options:0 |error|:(missing value)) forType:thisType)
else if (thisType's isEqualTo:"public.url-name") then
(thePasteboardItem's setString:(theNamesArray's objectAtIndex:0) forType:thisType)
else if (thisType's isEqualTo:"dyn.ah62d4rv4gu8zs3pcnzme2641rf4guzdmsv0gn64uqm10c6xenv61a3k") then
set theNamesWithLinefeedArray to (current application's NSMutableArray's arrayWithArray:{})
set theNamesArrayCount to theNamesArray's |count|()
repeat with i from 0 to (theNamesArrayCount - 1)
set thisName to (theNamesArray's objectAtIndex:i)
if i < (theNamesArrayCount - 1) then set thisName to (thisName's stringByAppendingString:return) -- necessary for OmniFocus. must be a return (a linefeed adds a blank line in Nisus Writer)
(theNamesWithLinefeedArray's addObject:thisName)
(thePasteboardItem's setData:(current application's NSPropertyListSerialization's dataWithPropertyList:{theURLsArray, theNamesWithLinefeedArray} ¬
else if (thisType's isEqualTo:"public.url") then
(thePasteboardItem's setString:(theURLsArray's objectAtIndex:0) forType:thisType)
display notification "Copied"
return true
activate
if the error_number is not -128 then display alert "Error: Handler \"copyRTFandMarkdownLink\"" message error_message as warning
error number -128
end copyRTFandMarkdownLink
