Script: Create or change smart group(s)
This script creates smart groups in selected group(s) or if nothing is selected a database-global smart group. It creates a meta group to hold database-global smart groups and a meta smart group which collects all group-specific smart groups.
If a smart group is selected it can be used to change the query and/or name. That’s especially useful to change existing smart group names to their query. To do so add a space to the query in the query dialog, this opens the name dialog. Also handy to update the name after changing a query via smart group editor. I find using the query as name (or part of the name) makes learning the syntax much easier.
As syntax mistakes happen quite easy and often over here there’s a help button which opens DEVONthink’s “search prefixes” page in the default browser. Property theHelpFileOrRefURL accepts a reference URL or URL too so a custom help resource could be used.
If text is selected it is used as default answer.
There are different modes to reveal/open created smart groups, however it’s not easy (for me) to choose one as each has advantages and disadvantages depending on the situation.
To make the meta group stick out a thumbnail can be set in a template record, “Smart” in the first capture is actually a group with a smart group thumbnail.
By the way @ngan made a script for normal searches.
-- Create or change smart group(s)
property theMetaGroupName : "Smart"
property theSmartGroupName : "_Subsets"
property revealInCurrentWindow : true
property openInCurrentWindow : false
property openInNewWindow : false
property openInNewWindows : false
property theHelpFileOrRefURL : ((POSIX path of (path to application id "DNtp") as text) & "/Contents/Resources/DEVONthink.help/Contents/Resources/pgs/appendix-searchprefixes.html") as string
property theIconPath : (((path to application id "DNtp") & "Contents:Resources:DEVONthink 3.icns:") as string) as alias
property theTemplateThumbnailUUID : ""
set theSearchGroups to selection of viewer window 1
if (count theSearchGroups) = 1 then
set theType to type of item 1 of theSearchGroups as string
if (theType = "smart group" or theType = "«constant ****DTsg»") then
my updateSmartGroup(item 1 of theSearchGroups)
return
set scopeDatabase to false
set theDatabase to current database
if theSearchGroups = {} then
set theSearchGroups to root of window 1
set theSearchGroups to theSearchGroups as list
on error
display alert "Hoppla!" buttons {"OK"} default button 1 message "Mehrfachauswahl in Seitenleiste nicht möglich." as informational
return
set scopeDatabase to true
if theType = "group" or theType = "«constant ****DTgr»" then set scopeDatabase to false
if uuid of item 1 of theSearchGroups = (uuid of theDatabase) then set scopeDatabase to true
else
repeat with thisSearchGroup in theSearchGroups
set theType to type of thisSearchGroup as string
set selectedText to selected text of window 1 & "" as string
set defaultAnswer to selectedText
set theSearchGroups to {theDatabase}
on error
set defaultAnswer to ""
set dialogButtons to {"Hilfe", "Abbrechen", "OK"}
set theDialog to display dialog "Suche:" default answer defaultAnswer buttons dialogButtons default button 3 with title "" with icon theIconPath
set {theButton, theQuery} to {button returned, text returned} of theDialog
if theButton = item 1 of dialogButtons then
do shell script "open " & quoted form of theHelpFileOrRefURL
return
else if theButton = item 2 of dialogButtons then
return
else
if theQuery = "" then return
set theMetaGroup to create location ("/" & theMetaGroupName) in theDatabase
if theTemplateThumbnailUUID ≠ "" then set thumbnail of theMetaGroup to thumbnail of (get record with uuid theTemplateThumbnailUUID)
if scopeDatabase = true then
set theSubsetsSmartGroup to {}
set theSmartGroups to (smart groups of theDatabase whose location is ("/" & theMetaGroupName & "/") and search predicates = theQuery)
if theSmartGroups = {} then
set theSmartGroup to create record with {type:smart group, search predicates:theQuery, search group:item 1 of theSearchGroups, name:theQuery, exclude from search:true} in theMetaGroup
else
set theSmartGroup to item 1 of theSmartGroups
else
if not (exists record at ("/" & theMetaGroupName & "/" & theSmartGroupName) in theDatabase) then
set theSubsetsSmartGroup to create record with {type:smart group, search predicates:"kind:smart group", search group:theDatabase, name:theSmartGroupName, exclude from search:true} in theMetaGroup
else
set theSubsetsSmartGroup to get record at ("/" & theMetaGroupName & "/" & theSmartGroupName) in theDatabase
set newSmartGroups to {}
set theSmartGroups to (smart groups of theDatabase whose location is (location of thisSearchGroup & name of thisSearchGroup & "/") and search predicates = theQuery)
set theSmartGroup to create record with {type:smart group, search predicates:theQuery, search group:thisSearchGroup, name:theQuery & " in: " & name of thisSearchGroup} in thisSearchGroup
else
set end of newSmartGroups to theSmartGroup
if revealInCurrentWindow = true then
set selection of window 1 to {theSmartGroup}
else
set root of window 1 to theSubsetsSmartGroup
set selection of window 1 to newSmartGroups
else if openInCurrentWindow = true then
set root of window 1 to theSmartGroup
else
else if openInNewWindow = true then
open window for record theSmartGroup
else
open window for record theSubsetsSmartGroup
else if openInNewWindows = true then
else
repeat with thisSmartGroup in newSmartGroups
open window for record thisSmartGroup
return
on updateSmartGroup(theRecord)
set {theName, theQuery} to {name, search predicates} of theRecord
set theDialog to display dialog theQuery default answer theQuery buttons dialogButtons default button 3 with title theName with icon theIconPath
set {theButton, newQuery} to {button returned, text returned} of theDialog
return
return
else
considering case
if newQuery = theQuery or newQuery = "" then return
end considering
set search predicates of theRecord to newQuery
set dialogButtons to {"Abbrechen", "OK"}
set theDialog to display dialog "Name:" default answer newQuery buttons dialogButtons default button 2 with title theName with icon theIconPath
set {theButton, newName} to {button returned, text returned} of theDialog
return
if newName = "" then return
if location of theRecord = ("/" & theMetaGroupName & "/") then
set name of theRecord to newName
else
set name of theRecord to newName & " in: " & name of parent 1 of theRecord
error number -128
end updateSmartGroup
