I enjoy using the reader view in Safari and printing a page to DTPO. I have a shortcut (cmd-P) that pulls up the print pdf menu and – thanks to David Sparks – a shortcut (a second cmd-P) that will print the pdf using my printer. But to print the pdf to DTPO I still must use the cursor to pull down the options and select print to DTPO, and I haven’t figured out how to create a shortcut for that last step.
Does anyone here have a shortcut to do this? Or can someone suggest the steps I could take to create that shortcut?
Well, that’s helpful. At least it gets me back to being sable to print to pdf and choosing a location.
But it still doesn’t help with saving as pdf to DTPO without using the drop down menu.
Saving directly to DTPO is crucial for me because it preserves the reference back to the source – which I’ll need if I ever use the material in my writing.
A fast way is to use the cmd P, then option cmd P. The first pulls down the print menu. The second triggers the “Save PDF to DEVONthink Pro” command in the sub menu. Set up option cmd P in the keyboard shortcut like you did cmd P. Very fast way to put things into devonthink inbox.
