I have Smart Folders set up to filter for various labels. Is there a way (maybe a script) to have a Smart Folder show me which items have no labels?
This would be really helpful to me, as sometimes I forget to add a label to an item, and this would be a quick way to make sure I don’t have any un-labelled items.
Hmm … doesn’t work for me. I get documents with and without labels, and when I open up the Smart Group edit window, I see that “Label is —” isn’t there. So I put it back in, and it doesn’t stick. Keeps disappearing.
The disappearing criteria indicates that the smart groups is not set up correctly-usually due to an incorrectly structured compound predicate. Can you post a screen shot of your smart group before you close it (while the Label is statement is still visible)?
