I have recently installed DT, and I anticipate that I am a novice. Nevertheless, I am trying to make it the central hub of my research apparatus, which currently consists of Bookends as a reference manager and Obsidian for taking notes in markdown. Both Bookends’ folder of attachments and Obsidian’s notes are already indexed in DT, but I lack to devise a solid and smooth workflow.
The first thing is to switch back and forth between DT’s indexed pdfs and Bookends’ references, hardlinking them. I have read about some scripts that allow to create links in the “user20” field in Bookends, and on the other hand in the finder comments of the DT file. Just this would be very useful for me, especially if it is possible to create a smart rule that does this in an automated way every so often, independently searching for files. Unfortunately, I have no scripting experience and wouldn’t know where to start, not even where they should be put to make them appear in DT.
The other issue, perhaps more tricky, is to understand (and discuss with you) what the best practices are for taking annotations on files.
If anyone is familiar with Bookends they will know that in addition to highlighting pdfs you can make annotations in the “notes” section, handling them as plain text (not markdown) or as “notecards.” However, I would not know how to index these pieces within DT.
The other method is to take notes on a specific book by creating a markdown in Obsidian indexed in DT, but the problem arises at this point of hardlinking it to the specific file in Bookends in a consistent way. DT has a very interesting system for creating annotations: creating a subfolder named annotations, with files in mardown inside linked to the respective files. The point is that using Obsidian I have a better markdown editor, with various plugins, and most importantly it allows me to group files into the specific subfolders I want, not limiting me to the database structure. Also being able to keep them on Dropbox to synchronize them on the fly with my Android phone (whereas DT’s “Annotations” files – correct me if I’m wrong – are created exclusively within the database and not externally, and only then indexed).
I noticed that @ryanjamurphy created a script a while back to manage the workflow between the three applications, but other than not knowing how to install a script, I can’t figure out if it would work for me. Possibly there are more updated or alternative scripts on the interconnection between these three software?
I apologize for the possibly confusing post but I would be curious to know experiences from those who are more skilled than me and have been in a similar scenario.
