Hello! What is the difference between syncing via legary and cloudkit, and is cloudkit syncing much better?
Sorry, I have no knowledge of computers.
I have update to DTTG3.0 and DTP3.6.2
If you didnât use iCloud sync locations so far (now called âiCloud (Legacy)â), then the new âiCloud (CloudKit)â sync locations are definitely recommended. Theyâre faster, synchronous and donât require as much CPU time.
Oh! Thank you for your amazing update work.
A question: if I have my old DT data on iCloud cloud, but I havenât used iCloud sync for a long time, and now I have many new files added to Devonthink on my computer. I now want to delete the data on iCloud and replace them completely with my current computer side data. What is the correct and safe way to do this?
Thank you very much.
Just clean the iCloud (Legacy) sync location by Control-clicking it and choosing Clean Location.
Also disable the legacy location on other Macs or in DEVONthink To Go before cleaning on the Mac.
Does CloudKit also use temp files on the drive, or is it now able to do without it? It was filling my drive like crazy.
The CloudKit sync is a single-stage sync writing directly to Appleâs server, similar to Dropbox.
What does clean location do? Didnât get any feedback message after doing it.
After that, I can remove location (legacy)? Do I then go to iCloud to delete any DB/files?
Cheers
Always check Window > Log or the Log popover in the toolbar. Youâll also see the database is unchecked and the message under the databaseâs name notes the database hasnât synced. And yes you could delete the legacy location, if you choose to.
Cheers.
@BLUEFROG Is there a way to see if we did the right order of disable/clean/remove on the Legacy iCloud parts? I think I did, but Iâd like to validate I donât have orphaned files taking up space in iCloud.
If you didnât do it correctly, databases would show up in the Remote section of the Databases list when you select the legacy sync location in DEVONthink.
Amazing! Thank you very much.
Youâre welcome
excellent! if this works more transparently it will have corrected the single biggest weakness of DT â syncing hassle! great job yaâll! now on to mailing items into DT directly! [wink wink]. Seriously I love DT and appreciate [and pay for] the continuous work yaâll do to make it better! great job and congrats to the team for the DTTG improvements.
Thanks
just downloaded the DTTG 3 and had to laugh at the snowy scenes background on the intro slides. I am at my house in South Florida and it is 73F [ca.23C] this morning with palm trees and bougainvillea outside. used to live in the Netherlands 15 minutes from Germany so I appreciate the difference.
I probably did something wrong, I today deleted on my mac 2 databases and I didnât sync this deletion with legacy sync.
I deleted the database on every other device, but it was after choosing cloudkit sync on them.
I still have them haunting me on cloudkit as remote even If I donât have them anywhere locally
Refresh doesnât do anything and clean is grey
Control-click the unwanted databases in the Remote section of the sync location and clean them. Simple and done!
Thanks! Yes, it worked now, I tried it before when databases were still syncing due to problem from the topic below. I wasnât able to do that, but after other databases synced it worked!
