First off, I just want to say that so far I really like the update and appreciate all the work that went into it.
With that said, I just want to bring up what seems to be change in viewing options that changes my workflow (unless I am missing something and that certainly is possible).
In DTPO 2 I live in the 3 Pane view with the widescreen option. There doesn’t seem to be the 3 Pane view option in DTP 3. It basically looks like some of the functionality of the second column (displaying the folder structure) was basically merged into the the first column by now being able to drill down the folder structure in open databases.
However, what seems to be missing is the ability to select multiple folders and have all the files contained in the selected folders display in the third column. In DTPO 2 the 3 Pane view with widescreen enabled there was a nice segregation between open databases (column 1), just the folder structure (column 2), the files contained in each folder (column 3), and the selected document itself (column 4).
The functionality of being able to select multiple folders in column 2 and have all the enclosed files displayed in column 3 was great and I used it everyday.
Now, with widescreen enabled, column one has the folder structure (but multiple folders cannot be selected, column 2 has a mix of both folders and files when viewed as a list (which looks cluttered when expanded), and column 3 has the selected document itself.
Am I missing something? Was this design change intentional, or is it just missing currently from the beta?
