Hi,
I’ve been working on a script to take Zotero items (from a BetterBibTeX JSON export) and create a set of DT groups and items, much like the earlier Bookends script. Because I can’t put info back in Zotero, I’m trying to use a plist file to store the citekey/DT uuid pairs so taht if e.g. the title of the Zotero item changes I will update the DT item. It works but is pretty slow. Any ideas for how to construct, modify, and then serialise/deserialise a dictionary of citekey/uuid pairs?
Script below, but health warning that it’s pretty untested, is unfinished, and doesn’t work properly yet.
use AppleScript version "2.4"
use scripting additions
use framework "Foundation"
-- all the settings should be here
set bibJSONFile to "/Users/lyndon/repo/workflow/zot-export-bbt-short.json"
set thePListFile to "/Users/lyndon/repo/workflow/zotero-to-devonthink.plist"
set theTemplateFile to "/Users/lyndon/Library/Application Support/DEVONthink 3/Templates.noindex/Education/Reference LD.md"
set theDTDBFile to "/Users/lyndon/DevonThink/Research.dtBase2"
set theDTLocation to "/Library"
property NSJSONSerialization : a reference to current application's NSJSONSerialization
property NSData : a reference to current application's NSData
set theJSONData to NSData's dataWithContentsOfFile:(bibJSONFile)
set theJSON to NSJSONSerialization's JSONObjectWithData:theJSONData options:0 |error|:(missing value)
set bibjson to theJSON as record
set therefs to |items| of bibjson
if exists property list file thePListFile then
set thePList to property list file thePListFile
else
set thePList to make new property list file with properties {name:thePListFile}
set theDatabase to open database theDTDBFile
set theLocation to create location theDTLocation
repeat with theRef in therefs
set {theKey, theTitle, theURI, theZoteroID} to {citationKey, title, uri, itemID} of theRef
set theTitle to |shortTitle| of theRef
set theGroupFile to theKey & " " & theTitle
set theUUID to ""
tell property list file thePListFile
set theUUID to value of property list item theKey
if theUUID = "" then
set theGroup to create location theDTLocation & "/" & theGroupFile
set theUUID to uuid of theGroup
set value of property list item theKey to theUUID
on error
tell property list items
make new property list item at end with properties {kind:string, name:theKey, value:theUUID}
else
set theGroup to get record with uuid theUUID
if theGroup is missing value then
on error
set theDOI to ""
set theDOI to DOI of theRef
set theAbstract to ""
set theAbstract to abstractNote of theRef
set theDate to ""
set theDate to date of theRef
set theURL to ""
set theURL to URL of theRef
set theAttachmentPath to ""
repeat with theAttachment in |attachments| of theRef
if (title of theAttachment) ≠ "Snapshot" then
set theAttachmentPath to |path| of theAttachment
set theAttachmentURI to uri of theAttachment
tell theGroup
set theAttachmentRecord to lookup records with path theAttachmentPath
if theAttachmentReord is missing value or (count of theAttachmentRecord) is less than 1 then
set theAttachmentRecord to indicate theAttachmentPath to theGroup
else
set theAttachmentRecord to item 1 of the AttachmentRecord
set custom meta data of the AttachmentRecord to {|date|:theDate, DOI:theDOI, abstract:theAbstract, citekey:theKey, zoteroid:theZoteroID}
set theCreators to ""
set multipleCreators to ""
repeat with theCreator in creators of theRef
set theCreators to theCreators & multipleCreators & |firstName| of theCreator & " " & |lastName| of theCreator & "(" & |creatorType| of theCreator & ")"
set multipleCreators to " and "
