As I noted above…
If you want instructions on a deep cleaning of DEVONthink 3 resources, open a support ticket.
As I noted above…
I had a few custom scripts which were “mapped” to custom buttons in the DEVONthink3’s toolbar. Unfortunately, these were not migrated. But I can live with that. Apart from that, the migration went super smooth! no issues with the databases or anything.
In my case, and no doubt for others, I had to delete the DT3 app before I could install DT4.
Discussed at some length here.
actually, that was an easy fix: the scripts from the toolbar are located in:
‘/Users/USER_NAME/Library/Application Scripts/com.devon-technologies.think3/Toolbar’
It’s sufficient to just copy the script and drag the button to the toolbar in DT4
Same here: I would highly appreciate a step-by-step instruction to upgrade from DT3 to DT4 (incl. the files mentioned above, as Custom Templates, Custom Scripts, Reinstall Custom toolbar items and anything else). That should include instructions to remove the DT3 installation.
Actually I would upvote this. Maybe my initial request was not super clear, or maybe I was “influenced” by some posts I read on beta version or so.
Anyhow if I need to say what I would like to know clearly is:
I’m aware of steps / procedure listed here “Switch to DEVONthink 4” and to me it seems like straight forward process with no need of zipping / deleting or anything.
So if that is that, me personally I’m ok with that, I’m not interested in “cleaning” DT3 files or whatever.
One reason for this is that I rely on scripts I developed for DT3 (many of them triggered via Alfred, but not only) which are very important in my daily workflow and allow me to work fast with notes, documents from many back2back meetings for example, where I don’t have much time for post-processing. If some of those don’t work with DT4, I would work in DT3 till I “upgrade” the scripts.
Hope these were clear questions ?
Thanks all for chiming in
As mentioned several times, you should not have DEVONthink 3 and 4 on the same account, on the same machine. If you want to keep version 3 to revert to at a later time, ZIP the application and delete the application.
Great, thanks clarifying that.
Now, further, can I kindly task to specify what to be zipped?
What files/folders ? Is it only the /Applications/DEVONthink 3.app or theres more to it ?
I think I’m not the only one not being sure on this.
Thanks
Just as I said and…
Only the app in the program folder should be zipped for the case you decide to go back to DEVONthink 3.
And after zipping move the DT 3 app in the Program Folder to the bin and empty the bin.
Keep Library/Application Support/DEVONthink 3. I would even keep it for the time being even after you have decided to stick to DEVONthink 4. There might still be something in it that’s of use to you.
Check if the Inbox folder in Library/Application Support/DEVONthink 3 is empty. And make sure no third party app sends files there, because now it’s a dead end. Re-route these third-party apps instead to Library/Application Support/DEVONthink/Inbox.
And something that might not affect many: DEVONthink 4 places its Inbox folder in the sidebar of the macOS Finder. But when you are using a third party file manager, say, Path Finder, you will have to replace the DT 3 Inbox folder in its sidebar with the DT 4 Inbox folder. It’s not new that the user has to put it there manually, but it is easily overlooked.
Thanks @suavito , I think this will be helpful.
Cheers
Good morning. I couldn’t see that a final specific and comprehensive tasklist had been posted in this thread so I’m providing one here, having gone through the process step-by-step this morning, documenting it as I went.
The whole process took 50 mins. This includes a Time Machine backup (15 mins) and manual backups of databases (25 mins). If you’ve already done these tasks upgrading the software is a 10 minute job.
Log into DT website and buy new license. (Hastily remember you have seats on a laptop you no longer own and remove them.)
Download DT4 from the success page after payment.
Do a final sync of any mobile devices to the main computer (this captures any changes you’ve made that haven’t yet synced, and depending on your sync can be achieved simply by opening DTTG on mobile devices and letting them sync).
Run Time Machine or your automated sync of choice.
Once Time Machine is complete, take a manual export of each database for safekeeping.
Close each database.
Close DT3.
TEA BREAK ![]()
Open the DEVONthink zip you downloaded.
Copy the new app to applications.
Open the new app.
I don’t know if this was normal, but for me DT4 couldn’t find my old databases via “Open database”, so I had to go to Finder and navigate Library>Application Support>DevonThink 3 and then open each of my databases manually. They opened automatically in DT4.
Check your databases look whole.
Eject DEVONthink installer.
Go to Applications folder and compress DT3. Move the file somewhere safe (I put it on the harddrive with my backups).
Move DT3 app to the bin (this is to uninstall it).
Restart device and open DT4. Check everything looks ok (if you have indexed folders, check they are still there!).
Delete DT3 from bin (this is to permanently remove it once you know everything is ok).
Take a deep breath, give yourself a nod for a job well done, and go play with DT4.
Hi all,
Since I initiated this topic, I would like to share my experience with the upgrade.
First off: I’m not saying this is the right way, I’m just sharing what I did and what I noticed, in case someone find it useful.
tell process "DEVONthink 3" totell process "DEVONthink" tell application id "DNtp" are working ok, no changes neededFor the last bullet point I created another post: DT3 → DT4 upgrade: Scripts Folder differences - DEVONthink - DEVONtechnologies Community
(! > Pls note this is on a test Mac, and not production < !)
After installing DT4, opening, mounting databases, dropping some emails from mail.app I did the following:
I didn’t do too much messing around but it gave me some peace of mind that I can run DT3 and mount the databases.
Hope this helps.
Cheers
