CleanMyMac is an app on SetApp.
It shows “System Junk” belonging to DevonTech
Are these truly files which can be deleted?
No idea what a “System Junk” is for CleanMyMac, I would highly recommend to check each folder & its contents. Actually we discourage the usage of CleanMyMac, it just causes too easily major issues.
Noted
That said - CleanMyMac reported a “partially installed” version of Clip to Devonthink. I installed it and it fixed this issue:
Now I get one request per website to verify I want to use the Web Clipper and otherwise it does not keep asking:
Though I only use Chrome for occasional support questions, you must have some setting different. I am not prompted to okay clipping per site.
Edi: Ugh! This is something Google just introduced in th 84 build. Grrr…
agree it’s annoying
But it beats having to do it every time!
