I use the Import to Selected Group and Delete script quite extensively, triggered as a Folder action when I add a file to the folder. At the moment it opens DTPO2, and I’m wondering what is the easiest way to modify/change this (if possible) so that the Folder action is tied to work with DT3. Or is there an alternative script I can use? I don’t see one in the DT3 script library.
I’m not script savvy, but could probably edit it if some kind soul could post easily followed instructions.
