Setting in DT3 is as it should be – switching off and on again does not help:
Bildschirmfoto 2019-10-06 um 00.11.18.pdf (491.1 KB)
Settings in Brother iPrint&Scan:
Bildschirmfoto 2019-10-06 um 01.41.58.pdf (79.8 KB)
Result is:
Bildschirmfoto 2019-10-06 um 01.32.18.pdf (242.8 KB)
Thank you for help.
Screenshots as PNG for easier viewing:
What is reported in DEVONthink’s Window > Log ?
It says:
~/Library/Containers/com.brother/iprint-and-scan/Data/Library/Caches/Brother.iPS/Temp/ScanToApp/
No text
Is Full Disk Access enabled in System Preferences > Security & Privacy > Privacy ?
Are you saving to the the Global Inbox?
Files added that way will not be automatically OCR’d.
You can use File > Import > Images (with OCR) or create a smart rule with an On Import event trigger.
I’m saving to the global inbox as I did before with DT 2.9.x and a Scansnap scanner. Nevertheless then incoming scans were automatically OCR’d but not now. When I change import preferences to “Select Group” the incoming scan asks for a group but nevertheless it will not be OCR’d.
Please elaborate what you mean by
TomsDad
October 8, 2019, 10:21pm
#9
For me, after installing DT3.0, the OCR software was not installed.
I right-clicked on the document, and selected OCR -> to searchable PDF
This triggered an install of ABBYY Finereader. Now all is good
Hope this help
It’s installed already – thank you.
Lost interest, Mr Neumann? Thank you for your continued support!
