setting "project" + "task" with “Add as To Do to OmniFocus”?
This script delivered with DEVONthink Pro Office creates the task in OmniFocus’ inbox.
I am looking for help on modifying this script, so that a dedicated project (“project-A”) and context (“context-A”) (both already existing in OmniFocus) is set via the script.
(I am starting these scripts via LaunchBar with assigned abbreviations that will already meet the project and/or context, so I am not looking for a change to this script that would bring up a dialogue box asking me to enter these information or prompting me to choose from a list with projects/contexts.)
This is the script code:
-- Script to add a selected record to OmniFocus as a to do
-- Written by Eric Böhnisch-Volkmann, Version 1.0.2, Aug 10, 2010
-- © 2010 DEVONtechnologies, LLC
-- Set properties
property pDaysIntoFuture : -1 -- Created to do will have a due date n days in the future
property pPrefix : "Reminder" -- Prefix for the created to do item
property pDelays : {{displayname:"No due date", value:-1}, {displayname:"Tomorrow", value:1 * days}, {displayname:"In two days", value:2 * days}, {displayname:"In three days", value:3 * days}, {displayname:"In one week", value:1 * weeks}, {displayname:"In two weeks", value:2 * weeks}, {displayname:"In one month", value:4 * weeks}, {displayname:"In two months", value:8 * weeks}, {displayname:"In three months", value:90 * days}, {displayname:"In six months", value:180 * days}, {displayname:"In one year", value:365 * days}}
property pDefaultDelay : "In one week"
-- Import helper library
tell application "Finder" to set pathToAdditions to ((path to application id "com.devon-technologies.thinkpro2" as string) & "Contents:Resources:Template Script Additions.scpt") as alias
set helperLibrary to load script pathToAdditions
	-- Get the selection
	tell application id "com.devon-technologies.thinkpro2" to set thisSelection to the selection
	-- Error handling
	if thisSelection is {} then error localized string "Please select a document or group, then try again."
	if (length of thisSelection) > 1 then error localized string "Please select only one document or group, then try again."
	-- Get and format the data we need
	set pLocalizedPrefix to localized string pPrefix
		set thisItem to first item of thisSelection
		set theSummary to (pLocalizedPrefix & ": " & name of thisItem) as string
		set theURL to (reference URL of thisItem) as string
	-- Let the user choose when to receive the reminder
	-- Convert array into localized arrays
	set pLocalizedDelays to {}
	set pLocalizedDelayNames to {}
	repeat with theDelay in pDelays
		set pLocalizedDelays to pLocalizedDelays & {{displayname:localized string (displayname of theDelay), value:(value of theDelay)}}
		set pLocalizedDelayNames to pLocalizedDelayNames & {localized string (displayname of theDelay)}
	set theChoice to choose from list pLocalizedDelayNames with title (localized string "Set reminder") with prompt (localized string "Please choose when you want to get reminded of the item") & " \"" & theSummary & "\"" & (localized string "%choice prompt end%") & ":" default items {pDefaultDelay}
	if theChoice is false then return false -- If the user pressed Cancel, exit
	set theDelayValue to pDaysIntoFuture -- Assume default
		-- Find the number of days associated with the user's choice
		repeat with theDelay in pLocalizedDelays
			if ((displayname of theDelay) as string) is equal to (theChoice as string) then set theDelayValue to (value of theDelay)
	-- Calculate due date
	if theDelayValue ≥ 0 then set theDueDate to (date (date string of (current date))) + theDelayValue
	-- Add new to do to OmniFocus
		tell application "OmniFocus"
				tell default document to set newTask to make new inbox task with properties {name:theSummary, due date:theDueDate, note:theURL}
			else
				tell default document to set newTask to make new inbox task with properties {name:theSummary, note:theURL}
	on error errmsg
		display alert (localized string "OmniFocus is not available.")
on error errmsg
	display alert (localized string "Error when adding item to OmniFocus") message errmsg
What would I have to add and where in this script to include a project and context, please?
Kind regards,
Bernd
Since the section of the script that you want to modify by hardcoding context and project is the portion that instructs OmniFocus to create a task (see snippet below), then you might find expert help for your request over at the OmniFocus/Extras forum. The original author of this script (Rob Trew) has been a frequent contributor to that forum.
This is where your change would occur:
			else
	on error errmsg
Thanks, I will surely ask over there, if none of the OmniFocus users active here joins in.
To get references to existing projects and contexts, you need to define a couple of functions which can be called like this:
tell application id "OFOC"
	set oDoc to default document
	set oProj to GetProject(oDoc, "project-A")
	set oContext to GetContext(oDoc, "context-A")
on GetContext(oDoc, strName)
		tell oDoc
			set lstContexts to flattened contexts where name = strName
			if length of lstContexts < 1 then return missing value
			return item 1 of lstContexts
end GetContext
on GetProject(oDoc, strName)
		tell oDoc
			set lstProjects to flattened projects where name = strName
			if length of lstProjects < 1 then return missing value
			return item 1 of lstProjects
end GetProject
Then using DevonThink’s supplied code, you should be able to make an edit like the following:
-- Set properties
		tell oDoc
end GetContext
		tell oDoc
end GetProject
on run
		-- Error handling
		-- Add new to do to named project
				set oProj to my GetProject(oDoc, "project-A")
				set oContext to my GetContext(oDoc, "context-A")
				set recProjContext to {project:oProj, context:oContext} as record
				tell oProj
						set newTask to make new task at end of tasks with properties {name:theSummary, due date:theDueDate, note:theURL}
					else
						set newTask to make new task at end of tasks with properties {name:theSummary, note:theURL}
				set context of newTask to oContext
		on error errmsg
	on error errmsg
end run
Rob, thank you so much for sharing your knowledge and time! You are the man I was hoping for.
Your script works brilliant and it even finds sub-contexts as I found out. This means real huge ease for me as I don’t use OmniFocus’ mail clipping. Instead I import all my email to DEVONthink Pro Office and create the tasks from there - and this is just one example. Thanks to you, I’ll have to work through OmniFocus’ inbox much less from now on. Super!
Best wishes from Germany,
Bernd
