I confirm that after a clean install, all my problems with DT have disappeard.
My Catalina install went without incident, but DT can no longer find my Epson to scan document, although scanning still works from Preferences. Not huge, just inconvenient.
Just letting you know: I have set DevonThink3 and Safari to open at start and when DevonThink3 Opens the little screen is transparent for a second or two. This didnāt happen with Mojave.
Is it DT3? I heard DT2 scan is 32bit.
Itās DT3
We are investigating an issue when using some scanners in DEVONthink in Catalina. Thanks for your patience and understanding.
Iāve been running it for a few days now. Faster and DT3 works w/o any problems. Only: faster
Does this also happen after launching DEVONthink 3 manually? A screenshot of your startup items might be useful. Thanks.
Yes, it happens if i close and open DevonThink, you can see a transparent little window.
https://www.dropbox.com/s/plwzbwtuhi3g2gl/DevonThink%20%23%20w2.mp4?dl=0
A screencast we could pause would be handy.
Done
Iām not able to get any successful syncs between DT3 and DTTG on my devices. Socket Errors and just spinning progressā¦
On Bonjour syncs?
I donāt believe I have had Bonjour syncs enabled. Iāll have to check when I get home.
Just checked. Yes, Bonjour is enabled with āIncoming Connections Available.ā
I get the blue dot in the cloud icon below and it is now working. I did update the Catalina Supplemental Update. Maybe that was it?
Are we still planning to wait before updating to Catalina? Do we have a date when this might be possible?
Hi everyone, first post here. My issue with Catalina is that I get a printing error when āprintingā a doc to Devonthink. Anyone else ?
Itās unclear what youāre referring to here.
We arenāt controlling the release of Catalina updates and we do not advocate moving to it now. Perhaps after the first of second revision of the OS, but again, thatās Appleās.
Thanks really helpful
