I have been running DTP on my laptop for about 6 months. I started syncing it with my iPhone a few months ago and that works well-enough (I don’t really use it on my phone other than to have access to things that I’ve filed). The sync is through iCloud.
This week I got a new iMac. So I want to run DTP there and sync it to my laptop. I installed it and set up syncing – as best as I could figure out. And they were syncing (I saw changes in one place happen in the other). But on both systems DTP would periodically crash … first on one then a while later on the other then a while later on the first… Throughout the day.
So I have complete de-installed DTP on the new system (and let Hazel clean up all the prefs, etc.) and want to start from scratch. What’s the best way? As a note – I use iCloud for the syncing to my phone but I do have fast peer-peer syncing for several folders between all of the systems (Resilio) and I don’t know if there is a better/faster way to sync (iCloud seems a bit slow).
Any thoughts or advice would be appreciated.
You certainly can set up multiple sync methods.
